Hi there!
I'm from the Netherlands. I'm owner of a Honda Civic from 1999 with a D14Z1 engine. The car isn't quite stock anymore...here is my mod's list:
Honda Civic EJ9
6th generation hatchback '99-'00 model
Engine:
D14Z1
Color
Bordeaux Red R-505P
Wheels
16" white DTM wheels ET45 4*100
15" gunmetal painted wheels 6.5J ET35 for circuit use
Tyres
Yokohama Advan Neova 205/45/16 (not installed)
Roadstone N2000 195/50/16
Yokohama Advan A048 195/55/15
Brakes
Front: Brembo MAX brake discs 260mm with Ferodo Racing brake pads
Back: OEM brake discs 240mm with Ferodo OEM brake pads (not installed yet)
Valvoline DOT5.1
ITR 1" master brake cilinder (not installed yet)
Goodridge stainless steel brake lines (not installed yet)
Engine modifications:
D16Y8 intake manifold
Hondata intake gasket
Filterbox EG 1.6
Pipercross airfilter
DCsports 4-2-1 exhaust manifold
Nividia testpipe 42cm
Custom made midpipe by APE:garage:
OEM EK9 muffler
P06 ECU ODB1 with CROME
123,6hp @ 7000rpm / 141Nm @ 5700rpm
D13 gearbox
TotalCarConcept light flywheel
Exterior modifications:
OEM EK9 window visors
OEM Hondasport rearlip
OEM EK9 wing
OEM EK9 grill
OEM Honda EP3 emblem
Modified 'OEM' Honda airducts
DIY EK9 look headlights
Tsunami frontlip
Interior modifications
OEM Del Sol VTi seats
Sparco carbon pedals
Cleaned empty trunk
LTEC steering wheel
APE:garage: X-strutbars
Suspension modifications:
OEM VTi strutbar front-up
Omnipower coiloverset sport
VTi swaybar rear
Megan H-brace
Hyperflex polyurethane rear trailer arm bushings
Beaks reinforcement kit
Beaks tie-bar
Megan control arms rear
Buddyclub P1 camber kit rear (not mounted yet)
You might see some pictures of the Civic, so here are some from last circuit weekend:
Some other random shots:
VIDEO!
Features:
ITB's on the D14 to test
Build D16Z6 N/A
To be continued!
http://www.sebastix.nl
http://www.omi-performance.nl
http://www.ape-garage.nl
